1. russell1256's Avatar
    I have an S9 running 8.0.0. This has happened twice, my phone will be charging at work on their wifi when my phone my phone starts a system update and tells me not to leave the wifi network. How do I stop these system updates. I have already turned off auto update, but it did not help. Anyone know how to stop this?
    Russ
    11-17-2018 03:26 PM
  2. SpookDroid's Avatar
    Are you sure it's a system update and not a policy update pushed by your company wifi? If a certificate or administrator was installed to be able to access the network they are able to push these and there is no way to block them other than disabling the certificates or administrator privileges (which would keep u ounfdom accessing the network).
    11-17-2018 09:40 PM
  3. russell1256's Avatar
    it is a system update, my company has nothing to do with this. It has happened other places also.
    11-18-2018 05:16 AM
  4. SpookDroid's Avatar
    That's odd because system updates will only warn you not to unplug or do it with a low battery, never not to disconnect from a network.
    Depending on your carrier/model some updates might be mandatory no matter what option you've set in your settings, but these are rare.
    11-18-2018 12:56 PM
  5. Rukbat's Avatar
    What you turned off was auto update of apps from the Play store. What you got was an update for Android, which is usually from Samsung. Different process, different app. You can delay Android updates, but only so many times, then it just updates without asking. Your best bet is after delaying the update the first time, when you're going to be home for a while, plug in the charger and do a system update. (It has to be at least 24 hours since the last one was delayed or you'll be told that the phone is up to date.)
    11-18-2018 01:11 PM
  6. SpookDroid's Avatar
    Oh crap. Yeah sorry, forgot that the option to not check for updates was removed from the system options! They'll ask you when it's available and not autodownload though
    11-18-2018 01:33 PM
  7. Javier P's Avatar
    Depending on the phone that option is now available in the Developer Options.
    SpookDroid likes this.
    11-18-2018 01:36 PM
  8. SpookDroid's Avatar
    Confirmed it's there for Sammy phones
    11-18-2018 01:38 PM
  9. Velenoso's Avatar
    I have an S9+ unlocked and I have to go to software in setting to find if I have a system update, even though I have it scheduled for a 2 am download, then I awake to a notiifcation of the system update, but it usually doesn't download it.
    I have to manually check for the update, but why would it worry you that much since they usually take no longer than 15 minutes at best to download and install.
    11-18-2018 01:50 PM
  1. Chrome Freezing After Software Update
    By js10 in forum General Help and How To
    Last Post: 12-06-2018, 04:08 PM
  2. new update
    By vader4633 in forum Samsung Gear S3
    Last Post: 11-27-2018, 08:50 AM
  3. Any updates on the LG K330 phone?
    By Donnie77 in forum LG K7
    Last Post: 11-17-2018, 08:56 PM
  4. lost all information on my SD card after updates 2 day's ago
    Last Post: 11-17-2018, 01:02 PM
  5. TMobile update available
    By Ryano89 in forum OnePlus 6 & 6T
    Last Post: 11-17-2018, 11:39 AM
