1. marsneyb's Avatar
    Would I be able to play videos in my vehicles drop down screen if I plugged my note9 into the RGB input ? (2015 gmc acadia) any advice is appreciated, thanks
    11-26-2018 05:48 PM
  2. SpookDroid's Avatar
    Maybe. Not sure if such a thing exists or not, but the only way to do that is to convert the video signal from the USB-C output (which, to the best of my knowledge, right now only supports HDMI and VGA connections) and turn it into an RGB/RCA output. For HDMI I really doubt such a converter exists, but for VGA it might...
    11-26-2018 05:54 PM
  3. Mooncatt's Avatar
    There's no direct plug in play solution I'm aware of. At minimum, you'd need something to convert the digital video signal to analog like this.
    https://www.startech.com/ca/m/AV/usb...dapter~CDP2VGA
    Then that needs to be converted to an analog signal like this.
    https://www.amazon.com/VGA-RGB-Cable...cUvbUpU6408504
    Of course, even that is no guarantee it'll work.
    11-26-2018 06:32 PM
  4. marsneyb's Avatar
    Sounds like more trouble than it's worth.... Thanks for the help
    11-26-2018 07:25 PM
  1. Go to Home Screen from Recent Apps view without Home button
    By PizzaPizza34 in forum Samsung Galaxy S7
    Last Post: 11-27-2018, 10:29 AM
  2. What happened to Gallery?
    Last Post: 11-26-2018, 11:57 PM
  3. Transferring videos from Samsung 5 to computer
    Last Post: 11-26-2018, 10:10 PM
  4. how to remove eyes that look like lights from a picture?
    Last Post: 11-26-2018, 05:57 PM
  5. Wireless charger not working when plugged in to fast charge
    Last Post: 11-26-2018, 04:55 PM
