1. trisha marie capoy's Avatar
    So here's my problem I have a samsung s3 version 4.3 so my problem is I cannot connect wifi far or any wifi in a public place that have a wifi and in my house I always in front of my router so I can connect it.
    So what is the problem of my samsung ? How can I solve it. It' so disappointed 😞
    And there's more And if I charge it the percentage of my phone is decreasing not increase. How do I fix this problem 😞
    11-30-2018 10:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! When you turn on wi-fi and look at the Settings>Wi-fi menu, do you see the list of all available networks and their signal strength, or does the list stay blank?
    The fact that your battery level drops while charging suggests that (a) whatever you're doing while charging is using more battery than the charging rate, and/or (b) your battery is old and failing. Try a new or different battery.
    12-01-2018 01:10 AM
  3. trisha marie capoy's Avatar
    Yes and their signal strength is strong but why I can't connect it say saved and secured but I can't connect.
    12-01-2018 02:53 AM
  4. B. Diddy's Avatar
    Are these open public wi-fi networks that are known to be connected to the web?
    12-01-2018 03:07 AM
  5. trisha marie capoy's Avatar
    I don't think so if the public wifi connected to the web. Well even in my house if I'm not near in my router I can't connect it say "saved and secured " but it's not connecting .
    12-01-2018 03:21 AM
  6. B. Diddy's Avatar
    Do you have a case on? Some poorly designed cases can actually interfere with reception.
    See if the problem persists in Safe Mode: https://support.t-mobile.com/docs/DOC-32821. If it does, then it is more likely to be a hardware problem. That phone is pretty old, so I wouldn't be surprised if it was failing.
    12-01-2018 03:24 AM
  7. trisha marie capoy's Avatar
    So what would I do sir ? It's not working anyways I can't connect even If I try the link you give.
    12-01-2018 03:34 AM
  8. B. Diddy's Avatar
    Here's the text from that link:
    Turn on and use safe mode
    Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
    1. Turn the device off.
    2. Press and hold the Power key.
    3. When 'Samsung Galaxy S III' appears on the screen, release the Power key Immediately after releasing the Power key, press and hold the Volume down key.
    4. Continue to hold the Volume down key until the device finishes restarting.
    5. 'Safe mode' will display in the bottom left corner of the screen. Release the Volume down key when you see 'Safe Mode.'
    6. Uninstall apps that are causing a problem.
    Turn off safe mode
    1. Press and hold the Power key.
    2. Tap Restart.
    3. Tap OK.
    12-01-2018 03:38 AM
  9. trisha marie capoy's Avatar
    Yes I try that but it's not working .
    12-01-2018 03:40 AM
  10. B. Diddy's Avatar
    In that case, it's probably a hardware issue. You could try a factory reset, but I doubt that'll do anything. It's probably time to get a new phone. Sorry!
    12-01-2018 03:43 AM
  11. trisha marie capoy's Avatar
    It's okay sir and thank you for your respond to may question.
    B. Diddy likes this.
    12-01-2018 03:45 AM
  12. trisha marie capoy's Avatar
    Oh by the way sir I have a follow up question if you don't mind.
    What is the difference if I update my older version to a new version anyways ?
    12-01-2018 04:05 AM
  13. hallux's Avatar
    Newer version of Android? That phone won't go beyond 4.3 officially.
    12-01-2018 07:38 AM
  14. B. Diddy's Avatar
    You'd have to find a custom ROM designed for that phone based on a higher Android version. Installing a custom ROM requires rooting the phone. And it probably wouldn't solve your problem, since it sounds like a hardware issue.
    trisha marie capoy likes this.
    12-01-2018 11:56 AM
  15. Rukbat's Avatar
    At a (experienced) guess, the antenna connector came loose, so the only "antenna" left is a little piece of copper - or the antenna itself went bad from shock (dropping the phone or knocking it against something). The "even in my house if I'm not near in my router" part is almost a label that says "bad antenna or bad wifi transceiver". If it's the transceiver, it probably doesn't pay to fix, because you'd have to have the motherboard replaced, and you can buy a gently used S7 for less than that would cost. (Most of the cost is the labor - you can get the motherboard itself for US$20.)
    12-01-2018 01:49 PM
  1. Galaxy S9 Plus photos of people arent clear or sharp
    By JoshuaD785 in forum Samsung Galaxy S9 & S9+
    Last Post: 12-03-2018, 10:08 PM
  2. Where is the sim card on my phone Samsung Galaxy 9
    Last Post: 12-01-2018, 01:35 AM
  3. Why do the black and white pixel 3s have different vibration types?
    Last Post: 12-01-2018, 01:14 AM
  4. Why does my Facebook and messenger app freeze up all the time now and has tracers
    Last Post: 11-30-2018, 08:50 PM
  5. Why does my phone keep pausing videos or shutting my live stream down?
    Last Post: 11-30-2018, 08:04 PM
