1. CashMoneyHahn's Avatar
    I can't get it to download any other apps on the phone without a problem in that not enough to be downloaded because of storage of lack of. I have only regular apps for the phone it came with.
    12-01-2018 03:31 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Show us a screenshot of the Settings>Storage menu: http://forums.androidcentral.com/gen...d-central.html
    If you don't have enough free internal storage, you'll need to free up space.
    12-01-2018 03:37 AM
  3. Rukbat's Avatar
    Some of that space may be taken by music, pictures, videos and other things besides apps. (And if it's an older phone and it's updated the Android version, that may have used some user storage too, as it got updated system apps.)
    12-01-2018 01:41 PM
  1. Can I replace camera class cover?
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 02-13-2019, 06:25 PM
  2. Always on Display Issue
    By zebra23 in forum Samsung Galaxy Note 9
    Last Post: 12-01-2018, 04:24 AM
  3. How to disable double tap unlock during calls on s7 Edge?
    Last Post: 12-01-2018, 04:02 AM
  4. How can It remove the floating icon from my home screen?
    Last Post: 12-01-2018, 03:06 AM
  5. Is there an opposite function to do not disturb?
    Last Post: 12-01-2018, 01:25 AM
