1. Peter Steiner's Avatar
    On Android v7 there was a folder in root directory called "data".
    I created in the past some subfolders and copied some files there.
    When I connected from WinPC to the smartphone through USB cable I could see all these folders and files successfully in WinExplorer.
    So it must work somehow.
    Then suddenly a few weeks ago the content was not visible any more through USB connection.
    It was only visible through FileManager Apps on the SmartPhone iself.
    Why?
    I must have changed accidentially something .But what?
    As a work around I renamed the old folder to "dataold", then created a new folder "data" and copied all content from old "data" folder to new "data" folder.
    ....and bingo! all files and folders in new "data" folder are visible (again) through USB connection.
    However the non-visibility in the old "data" folder is strange.
    How can this happen?
    Thank you
    Peter
    12-03-2018 04:57 AM
  2. Rukbat's Avatar
    The old folder didn't have read rights for everyone, maybe? Did you check the rights?
    12-03-2018 11:34 AM
  1. Why the app shows update after the install instead of open button
    Last Post: 12-03-2018, 11:39 AM
  2. Andriod Auto not working on Google Pixel 3
    Last Post: 12-03-2018, 03:14 AM
  3. Why wont my 32gig scandisk (dual ended) usb stay on longer than 30 seconds?
    Last Post: 12-03-2018, 12:59 AM
  4. Any idea of this app? NOT ON MY PHONE
    Last Post: 12-02-2018, 04:57 PM
  5. Video files are showing up in gallery idont want it there.
    Last Post: 12-02-2018, 03:44 PM
