    I have cleared cashe and data before uninstalling unused apps i use my lg stylo3 for a hot spot for this tablet
    12-04-2018 03:54 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Show us a screenshot of the Settings>Storage menu: http://forums.androidcentral.com/gen...d-central.html. You'll have to register on this forum first. https://forums.androidcentral.com/as...community.html
    12-04-2018 04:50 PM
  3. Squarebodys's Avatar
    I have deleted cashe and data from all unused apps to make room for update i use my lg stylo 3 hot spot for the tablet is there anything i can do to make room without unrooting it?
    12-05-2018 06:05 PM
  4. hallux's Avatar
    Someone responded to your anonymous question yesterday - https://forums.androidcentral.com/as...ng-system.html
    12-05-2018 06:26 PM
  5. B. Diddy's Avatar
    I merged the threads. My response to your previous post still stands -- show us a screenshot of the Storage menu.
    12-05-2018 07:54 PM
  6. Squarebodys's Avatar
    Ok sorry just trying to figure out how to do it
    12-05-2018 07:57 PM
  7. Squarebodys's Avatar
    12-05-2018 08:15 PM
  8. hallux's Avatar
    There was a guide on posting screenshots linked in the first reply - http://forums.androidcentral.com/gen...d-central.html
    12-05-2018 08:22 PM
  9. Squarebodys's Avatar
    Is that ok how i did it or do i need to go to the link
    12-05-2018 08:29 PM
  10. B. Diddy's Avatar
    I recently saw another post with similar storage stats that didn't make much sense, and it was also from a Samsung device that was using Clean Master to "power" the Device Maintenance app. Try installing DiskUsage and see if that gives more accurate information.
    12-05-2018 08:56 PM
  11. Squarebodys's Avatar
    12-05-2018 09:23 PM
  12. Squarebodys's Avatar
    12-05-2018 09:34 PM
  13. B. Diddy's Avatar
    This screenshot is for the SD card. Can you show us the screenshot for Internal Storage?
    12-05-2018 10:29 PM
  14. Squarebodys's Avatar
    12-05-2018 10:51 PM
  15. B. Diddy's Avatar
    Ok, that makes a bit more sense. It's showing that of the 16 GB of internal storage that your tablet comes with, only 10.6 GB is available to the user (the other 5.4 GB are taken up by the OS and by preinstalled bloatware). Of that 10.6 GB, 3.32 GB are taken up by apps (including app data), and 5.92 GB are taken up by media files (photos, videos, music). These aren't necessarily files that you manually downloaded -- it might be cached data from your Google Photos or Google Play Music app, for example. 1.29 GB of that 5.92 GB of media is listed as "Downloaded," suggesting that you had downloaded at least some of it from the web.
    Check the Download directory to see if you have a lot of media files there. Also, open your various media apps (like Google Play Music, YouTube, etc.) and look in their settings for an option to clear the cache. You can also go to Settings>Apps, select those apps, and clear the cache there as well. You can also clear data, but this will remove your account from the app as well -- you can always log back in, but any data from the app you might have saved would be wiped out.
    12-05-2018 11:33 PM
  16. Squarebodys's Avatar
    12-06-2018 11:26 AM
  17. Squarebodys's Avatar
    I sure appreciate your help and patience im not very tech savy with all this smart stuff but i can tear your transmission apart and make it work better than it did lol. Do you think i should just get another tablet with more internal memory? Thanks again
    12-06-2018 11:33 AM
  18. B. Diddy's Avatar
    The problem is that there actually aren't that many good affordable tablets out there with more than 16 GB, but yes, that would be a good idea if you want to keep a good number of apps installed on the device. For now, I would go through your app list on your current tablet and uninstall any apps you hardly use, then see how much space you recover.
    And I think fixing a transmission is much more impressive than any of the stuff we talk about here.
    12-06-2018 02:33 PM
  19. Squarebodys's Avatar
    You was exactly right i finally found a bunch of downloads over 80 of them lot of them were 83 m bthat took it down to around 13.4 enough to install oreo update lot of them were service manuals is there a way to download them go google photos? I cant thank you enough i even got speed back
    B. Diddy likes this.
    12-06-2018 03:31 PM
  20. hallux's Avatar
    You could use Google Drive to store stuff, your Google account comes with 15 GB of space for free.
    12-06-2018 03:47 PM
  21. B. Diddy's Avatar
    Great! I agree with hallux -- save those manuals to Google Drive (or any other cloud storage you might have access to). You can do that on your computer -- it doesn't necessarily have to be done through your tablet.
    12-06-2018 04:05 PM
  1. LG K20 Plus stuck on Android Update for HOURS
    Last Post: 01-07-2019, 09:07 AM
  2. Dropped Galaxy S7 - blue/purple and unresponsive screen at the bottom
    Last Post: 12-04-2018, 05:05 PM
  3. What's your photo aspect ratio? 16:9 or 4:3
    By PaulQ in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-04-2018, 04:49 PM
  4. How do i get the tiny scripts that is running on the side of my phone off
    Last Post: 12-04-2018, 02:34 PM
