1. chrispmoto's Avatar
    Hi.
    Is there a way to automatically connect to a certain extension when I call a business?
    For example, when I call my wife's work number, I always have to enter the extension number after "it answers"....
    Is there a way to do this automatically...
    Even with Assistant??
    Thanks.
    12-05-2018 08:13 PM
  2. B. Diddy's Avatar
    I moved this from the Android Apps forum to the General Help forum, for more specific traffic.
    You could add the extension to the phone number saved in the contact entry -- just separate the extension from the main phone number with 1 or 2 pause commands (typically a # or p).
    12-05-2018 09:01 PM
  3. hallux's Avatar
    Only if the company's phone system allows it to happen. The closest you can do is to include a wait in the contact number and act on the prompt when needed.
    @B. Diddy literally 2 minutes ahead for the second post in a row..
    B. Diddy and chrispmoto like this.
    12-05-2018 09:03 PM
  4. methodman89's Avatar
    Have her call you from one of the rollover lines. Then when line 6 rings even though 1 through 5 aren't busy, you'll know who's calling. Used to work for me.
    12-06-2018 07:43 AM
  1. Samsung s9 plus photo upload to imac
    By Wayne Clifford1 in forum Samsung Galaxy S9 & S9+
    Last Post: 12-06-2018, 01:51 PM
  2. Call screen may have flaws if you actually plan on calling someone back
    By PaulQ in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-05-2018, 09:50 PM
  3. My S7 went back to factory settings
    Last Post: 12-05-2018, 07:52 PM
  4. Is my phone gone for good?
    Last Post: 12-05-2018, 07:51 PM
  5. Why is my galaxy tab a using 15.3of 16.0 gb for operating system
    By Squarebodys in forum General Help and How To
    Last Post: 12-05-2018, 06:26 PM
