1. KeriT56's Avatar
    Is it possible for PC to directly see mobile phone's NFC reader in such way, that mobile phone's NFC reader would function in the same way as off-the-shelf stand-alone USB NFC reader?
    I want to use smart card for authentication purposes on PC via mobile phone's NFC reader.
    12-06-2018 03:16 PM
  2. SpookDroid's Avatar
    Nope. Only the phone's system can access it (it's a security thing). You can transfer data from the phone to the PC upon NFC action tags with an automation app like Tasker (probably needs root) BUT you can't transfer data directly from the NFC tag to the PC or use the reader from the PC (you can only do NFC to Phone, then action/copy/write from Phone to PC. This obviously would not transfer any encrypted/secure token or data).
    12-06-2018 04:48 PM
  3. Rukbat's Avatar
    You could develop an app that could both read the NFC reader and communicate with a PC, but there's no way a PC could do it without an app. Something that uses
    Code:
         <intent-filter>
             <action android:name="android.nfc.action.DISCOVERED" />
         </intent-filter>
    12-06-2018 05:13 PM
  1. Newbie fresh from windows phone refugee camp
    By Kavu2 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 12-10-2018, 05:46 PM
  2. Replies: 2
    Last Post: 12-06-2018, 03:36 PM
  3. How can I fix wireless keyboard lag with my android tablet?
    Last Post: 12-06-2018, 02:58 PM
  4. Why I can't dowload or update apps from playstor
    Last Post: 12-06-2018, 02:54 PM
  5. Replies: 1
    Last Post: 12-06-2018, 02:44 PM
