Hello i have this notification "Network may be monitored" on the notification screen ( https://imgur.com/a/kPIsFdb ). I'm using an Adblock app DNS66. Is there any way to remove the message whitout root or uninstalling the app ? Thanks !
Samsung Galaxy S9 / Android Oreo
