1. Zoe Graystone's Avatar
    The only option for ringtones & notification settings is "Sounds" & I can't figure out how to add to the app
    12-11-2018 10:55 AM
  2. hallux's Avatar
    What app? Are you looking to set an actual ringtone or a notification sound for a particular app?
    12-11-2018 11:54 AM
  3. Zoe Graystone's Avatar
    I want to set a ringtone from a file. None of my ringtones transferred to my Pixel 3 as ringtones. They are in a file on my phone but I can't access them to assign to contacts or use
    12-11-2018 12:12 PM
  4. hallux's Avatar
    Use a file manager (I prefer Solid Explorer and steer people away from ES File Explorer) and move the audio files into the ringtones folder. After doing that they should be available to pick from when setting a ringtone through Contacts.
    Unless you want to get into 3rd-party apps for "hacking" it to work, this is the best option for a "natural" process.
    12-11-2018 01:10 PM
  1. Can't get messenger app
    By Android Central Question in forum Android Apps
    Last Post: 12-16-2018, 08:34 PM
  2. Why is there a speaker icon appearing on my Samsung J8 every 15mins?
    Last Post: 12-16-2018, 08:33 PM
  3. on my Polaris tablet why doesn't the left side of my screen respond to touch?
    Last Post: 12-11-2018, 12:06 PM
  4. Pixel 3 Contact Groups
    By Warhammer486 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-11-2018, 10:46 AM
  5. can i add 128 giga sd card to nvidia shield tv ?
    By kalua123 in forum Ask a Question
    Last Post: 12-11-2018, 09:18 AM
