1. Nvizhon's Avatar
    I am trying to get rid of the old phone number for a contact without deleting the contact. I minused the old one but it still shows on the contact
    12-15-2018 06:17 PM
  2. ManiacJoe's Avatar
    Check for duplicate entries. I have had the mistake of separate entries saved to the phone and saved to Google.
    belodion likes this.
    12-15-2018 07:37 PM
  3. hellosailor's Avatar
    There may be multiple contact lists, samsung and others add a "contact" app that it not the same as your gargoyle contacts. So you may need to confirm there is just one list, whichever one yoh want to use. In Android8 you need to open the contact, select EDIT, then there should be a little - sign at the right side of each phone number. Select the minus, and make sure to select SAVE from up top.
    Open the contacts in gargoyle and check/edit them on a computer to confirm, if need be.
    12-15-2018 08:16 PM
  1. Separate phone ringtone and notification volume?
    By rimz808 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-21-2018, 01:05 PM
  2. Google pixel phone memory concern
    Last Post: 12-18-2018, 01:07 PM
  3. What should i do to get rid of maximum window limit reached
    Last Post: 12-18-2018, 11:31 AM
  4. Ring doorbell notifications wont override phone on mute
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 12-15-2018, 08:42 PM
  5. I have a S8+ and I’m using smart view but I have no audio going to my Tv
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 12-15-2018, 06:07 PM
