1. Kay Stone1's Avatar
    Bought a syncing cable but that's as far as I've gotten.
    12-19-2018 05:19 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. What are you trying to sync?
    12-19-2018 05:21 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Also, which devices do you have? Android devices sync with each other through your Google account in the cloud, so there's typically no use for a cable to connect the two devices. An exception might be certain manufacturers that have proprietary software that allows two of their devices to connect together.
    12-19-2018 05:35 PM
  1. To "T", or not to "T"?
    By ScottRx82 in forum OnePlus 6 & 6T
    Last Post: 01-16-2019, 09:06 PM
  2. Way to reduce OS size/partition?
    Last Post: 12-19-2018, 05:31 PM
  3. How do I shut off my voice assistant that reads my texts to me
    Last Post: 12-19-2018, 05:22 PM
  4. My galaxy s6 is not turning on
    Last Post: 12-19-2018, 05:17 PM
  5. Is there a way to choose mic?
    By Lars Rossetnes in forum Ask a Question
    Last Post: 12-19-2018, 04:25 PM
