1. 2lonestar's Avatar
    A screenshot my niece sent had this icon, her parents let her do whatever on her phone and I just want to make sure she isn't getting into trouble. Anyone know what this icon is.
    Three circles and a shield in a 2x2 position, shield in the bottom right position. Thanks anyone that can help. I've cruised through a lot of the playstore, no luck.
    12-19-2018 10:57 PM
  2. SpookDroid's Avatar
    I can't for the life of me remember exactly what it was, but I can tell you what it isn't: an app. So don't worry, there's nothing 'funny' going on, it's definitely a system icon. I'm gonna have to do some memory digging (or if you could post a larger picture?)...
    2lonestar likes this.
    12-20-2018 12:08 AM
  3. 2lonestar's Avatar
    That's the only pic I have, unfortunately, but knowing it's system related is very helpful, thanks!
    If you remember what it is later, let me know anyway, thanks again
    12-20-2018 09:38 AM
  4. SpookDroid's Avatar
    I knew I'd seen it!
    Permissions monitor... Pretty standard, normal behavior.
    Pls Identify 3 circle and shield Icon-smartselect_20181220-173550_nova-launcher.jpg
    B. Diddy, 2lonestar and Morty2264 like this.
    12-20-2018 07:50 PM
  5. 2lonestar's Avatar
    Thanks for being so helpful!
    12-21-2018 01:07 AM
  6. SpookDroid's Avatar
    Not a problem!
    12-23-2018 09:35 PM
  7. Morty2264's Avatar
    Mystery solved! Awesome!
    12-23-2018 10:04 PM
  1. My Gyroscope and Accelerometer sensor can't steady
    Last Post: 12-21-2018, 06:37 AM
  2. App stucks and pressing home button does nothing
    By lcneed in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 12-20-2018, 01:48 PM
  3. samsung galaxy tab a6 not turning on and screen flickerign
    Last Post: 12-19-2018, 05:48 PM
  4. Ethernet adapter and Charging - Tablet
    By jonnyt88 in forum Samsung Galaxy Tab
    Last Post: 12-19-2018, 04:03 PM
  5. How do I use the flip top to switch my samsung j3 phone on and off
    Last Post: 12-19-2018, 11:51 AM
