How can i reverse the sleep mode on a huawei Y6 2018?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Welcome to Android Central! Which thread are you referring to? I tried to search for a thread about sleep mode in the Y6, and couldn't find one. If you can find the thread, then just make sure you're logged into your Android Central account, select that thread, and click the Reply button.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Wow, good detective work @Rukbat!:)
@Judith Downes, if that's the thread, then even though it's old, it's still worth posting your solution. You never know who else might have the same issue and bring up that thread. So click Rukbat's link, make sure you're logged into the forums, and post your reply.
