I set up the voicemail with tech support from Tracfone. Under call settings the only thing listed is vibration notification. As a senior citizen I really need a visual notification. Please help me.
Welcome to Android Central! When you open the Phone app and tap Menu>Settings, what other options do you see? Can you ask the TracFone tech support people for further assistance?
