First of all sorry for the same questions, but for some reason I can't respond to the answers i have been kindly given
My daughter has locked her tablet, I have tried different combinations of switching on with Volume + and Power but non have worked. I can get to the part where I can wipe data and factory reset but there is only the option to select No. With this in mind I have discovered that there is a pinhole to reset it. Does the tablet need to be on or off when I use a pin in the reset hole.Are there other things to consider when trying this option.
The tablet is a Chinese running KIkat 4.4 whatever that means.
thanks very much
12-30-2018 03:36 PM
