1. Jslloyd54's Avatar
    Hi. Recently moved over from iPhone to pixel and love it. Have some issues with opensong and hoped I cud get some answers here. I currently use. Onsong for musical performance lyrics etc Nd want to transfer the bak file of songs to Opensong. The app info tells me to copy into a folder. But when I use files app I can't see these folders. Are the folders the app makes emulated? And how do I put a file in there!!! Any help wud be much appreciated.
    01-06-2019 02:26 AM
  2. belodion's Avatar
    Thread moved from Introductions.
    01-06-2019 07:17 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you talking about OpenSongApp? What format are the files you want to transfer? It looks like the app says it will convert OnSong format to OpenSong.
    Did you already look here for support? OpenSongApp
    01-06-2019 05:29 PM
  1. Replies: 1
    Last Post: 01-05-2019, 12:52 PM
  2. Galaxy S9+ Problem with Selfie Mode
    Last Post: 01-05-2019, 03:56 AM
  3. Replies: 1
    Last Post: 01-04-2019, 05:59 PM
  4. Blu phone internet connection problems
    Last Post: 01-04-2019, 02:38 PM
  5. How to solve reverse charging display problem in asus zenfone max pro M1
    Last Post: 01-04-2019, 02:14 PM
