1. iainharwood's Avatar
    Can anyone provide step by step instructions to move music etc from iPhone to Android
    01-08-2019 11:25 AM
  2. SpookDroid's Avatar
    Hi there! This guide might help.
    https://www.androidcentral.com/switching-iphone-android
    You didn't mention which phone you're moving to, but if it's a Samsung one, the easiest way to do it is to use SmartSwitch. Pretty much does it all for you, just install on both phones, connect, select what you want to transfer, done!
    While Apple Music is on Android, if you'd prefer a local file alternative to iTunes, most people recommend AirSync/DoubleTwist.
    01-08-2019 12:00 PM
  3. iainharwood's Avatar
    Thankyou, will research the Samsung smartswitch.
    01-09-2019 12:12 AM
  1. Why does my Samsung J-3 after getting through the lock screen go to the keypad
    Last Post: 01-08-2019, 01:25 PM
  2. Replies: 1
    Last Post: 01-08-2019, 11:04 AM
  3. Replies: 0
    Last Post: 01-08-2019, 10:37 AM
  4. Why can't I run the app in my physical phone in Android Studio?, Xubuntu 32 bits.
    Last Post: 01-08-2019, 10:20 AM
  5. Google play music EQ replaced after Android upgrade ?
    By Android Central Question in forum Android 8.0 Oreo
    Last Post: 01-08-2019, 09:42 AM
