1. Murph5150's Avatar
    I powered off my old cell phone and removed it (Moto E4+). I then placed it in my newer phone, (the Droid 2 Force). I now get a message that says thd SD Card is corrupt but I can reformat it two different ways. I tried to reformat the card, both ways using both phones, and the card remains corrupt.
    Does anyone have any advice or suggestions? I'd appreciate it very much!
    01-10-2019 01:03 PM
  2. Kodak2's Avatar
    There is a chance that it's a counterfeit card. SanDisk cards do have a good warranty, so depending on how long you have had the card, return it for replacement. I have seen a post recently directing to an app to check the card (Rukbat?). You could also check it out in a PC if you have one.
    Laura Knotek likes this.
    01-10-2019 01:56 PM
  3. Laura Knotek's Avatar
    Have you tried inserting the card in the card reader on a PC and using the chkdsk command?
    https://docs.microsoft.com/en-us/win...ommands/chkdsk
    01-10-2019 01:57 PM
  4. Rukbat's Avatar
    The app is SD Insight, but if the phone can't read the card, the app can't either.
    SanDisk is pretty good at replacing cards though - try SanDisk microSD Tech Support, upper right corner, live chat. The shortest warranty is 5 years, so the card should be covered.
    Kodak2 and Laura Knotek like this.
    01-10-2019 04:31 PM
  1. Replies: 2
    Last Post: 01-08-2019, 09:53 PM
  2. Email attachments missing/corrupted
    By emil7 in forum General Help and How To
    Last Post: 12-27-2018, 05:03 PM
  3. Acer Chromebook R11 Keyboard corrupt mapping
    By Android Central Question in forum Acer Chromebooks
    Last Post: 12-25-2018, 12:35 AM
  4. Acer Chromebook R11 Keyboard corrupt mapping
    Last Post: 12-24-2018, 03:15 PM
  5. Will my data corrupt or something?
    By UserMango in forum Ask a Question
    Last Post: 12-14-2018, 01:22 PM
