1. Gatchang Mabany's Avatar
    I think the problem is the system UI which I don't know how to solve it ; I cannot receive a call, set a ring tone, and so many more like clearing recent apps. I tried to factory reset it and also wiping the cache from the recovery mode but there's no solution. I need your help guys
    01-11-2019 02:22 PM
  2. belodion's Avatar
    Welcome.
    What makes you think that it's not simple straightforward hardware failure?
    01-11-2019 06:08 PM
  3. RavenLte's Avatar
    Also, go to a corporate store, if local and have them check it. Most carriers check phones for free. Always did for me.
    09-19-2019 10:48 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Is the screen completely black, or is there some very minimal information on it, like the clock in the status bar?
    09-19-2019 11:50 PM
  1. is time to bin my LG V20? but for what?
    By gordiebear in forum LG V20
    Last Post: 06-11-2019, 01:33 PM
  2. Replies: 1
    Last Post: 01-12-2019, 12:39 AM
  3. Yes i was just wondering what was wrong with my android
    Last Post: 01-11-2019, 04:53 PM
  4. Chrome URLs opening in Samsung Internet Browser?
    Last Post: 01-11-2019, 03:52 PM
  5. Change my icons color from blk to white
    Last Post: 01-11-2019, 03:50 PM
