1. Warsame Jibriil Yuusuf's Avatar
    It says my PS4 controller is connected to my phone on Bluetooth settings under, "wireless controller". It used to work all fine until today. I tried doing it again and it said it was connected but I could not use it at all. Did not work in any games (including supported games/emulators) and did not even work on the home page! Been trying to fix it for the past 5 hours but all fixes on the internet that I could find did not work for me. Also, my Bluetooth headphones also started not to connect to my phone so I believe it's a problem with my Bluetooth on my phone and not a problem with any of my devices (headphones connected perfectly to a friend's iPhone.)
    01-11-2019 09:24 PM
  2. Rukbat's Avatar
    It sounds as if the Bluetooth radio in your phone went bad. That normally means a motherboard replacement.
    01-12-2019 02:53 PM
  1. Replies: 5
    Last Post: 01-18-2019, 05:37 PM
  2. Xiaomi A1 after upgrade to Android 9 do not connect to WIFI
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 01-16-2019, 10:54 PM
  3. Apps get stop when I connect or disconnect Mobile charger
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 01-12-2019, 08:16 PM
  4. Pixel 2 XL USB-c / 3.5 mm audio issue
    Last Post: 01-12-2019, 02:57 PM
  5. Xiaomi A1 after upgrade to Android 9 do not connect to WIFI
    Last Post: 01-12-2019, 08:36 AM
