My LG-AS330 phone is running very low on memory
Hello,
I have a LG-AS 330 cell phone. My phone runs on Android 5.1.1. My phone has a capacity for 8GB of internal memory, but I only have 300 MB of internal memory available. I have cleaned the cache, and I have very few apps on my phone. I do have a SD card installed but my phone doesn't use the SD card for storage. How can I increase the internal storage on my phone?
Thank you
Re: My LG-AS330 phone is running very low on memory
Welcome to Android Central! You can't increase it -- you're just stuck with very little usable storage. It's time to start thinking about a new phone. See this guide for tips on how to maximize what little storage you have: https://forums.androidcentral.com/am...-warnings.html
Thanks for the reply B. Diddy!
