1. cinque8's Avatar
    Hello,
    I have a LG-AS 330 cell phone. My phone runs on Android 5.1.1. My phone has a capacity for 8GB of internal memory, but I only have 300 MB of internal memory available. I have cleaned the cache, and I have very few apps on my phone. I do have a SD card installed but my phone doesn't use the SD card for storage. How can I increase the internal storage on my phone?
    Thank you
    01-13-2019 09:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can't increase it -- you're just stuck with very little usable storage. It's time to start thinking about a new phone. See this guide for tips on how to maximize what little storage you have: https://forums.androidcentral.com/am...-warnings.html
    01-13-2019 11:47 PM
  3. cinque8's Avatar
    Thanks for the reply B. Diddy!
    B. Diddy likes this.
    01-14-2019 12:01 AM
  1. Kinda got stuck with this phone
    By Faintestidea in forum LG G7 ThinQ
    Last Post: 01-24-2019, 11:08 PM
  2. Phone freezing/crashing after ARL1 (T-Mobile) update?
    By BigMosely in forum Samsung Galaxy Note 9
    Last Post: 01-14-2019, 03:29 PM
  3. Can't access music on SD after Android 9 upgrade
    Last Post: 01-14-2019, 09:51 AM
  4. I can't get my app mover to work on my home screen
    By Arod71 in forum Samsung Galaxy Note 3
    Last Post: 01-14-2019, 03:52 AM
  5. My LG G4 screen keeps shutting down and then restarts
    Last Post: 01-14-2019, 03:51 AM
