1. nola mike's Avatar
    Been playing around with some Pie ROMs and now my SD card is showing as unreadable in the OS. Also not recognized on linux box, and with windows it's showing as RAW filesystem. Usually when this happens to me it's a corrupted partition table and can be fixed by chkdsk (that's why I didn't spend much time with it in linux). Not this time I guess. The strange thing is that I can read/write files using the TWRP file manager, so I know that my data is there and it's probably a pretty easy fix. I'll probably end up formatting it and getting rid of this god awful exFat system if I can't fix it, but I don't feel like copying 64 gb of data back and forth if I can help it.
    01-15-2019 07:45 AM
  2. Golfdriver97's Avatar
    SD cards (well, all forms of data storage, actually) have a finite number of read and write cycles. If the card has some age to it, it may just be shot as well. In my experience, when a drive of any kind starts becoming corrupted, I usually replace it.
    B. Diddy likes this.
    01-15-2019 08:11 AM
  3. nola mike's Avatar
    Well, android is funny with SD cards. Turns out the fix was easy. The kernel that I was using has a problem with exfat cards (fairly common it seems). Flashed a different kernel, and all is well. Don't know why I couldn't read it using a card reader on 2 systems though, guessing a bad card reader.
    01-15-2019 11:28 AM
  4. Rukbat's Avatar
    Thanks for pointing out the fix, though. It's something for us to keep in mind, if someone has a problem and isn't using the stock kernel. (It's possible that, in trying to read it, the "defective" kernel did something to the filesystem [even just changed a bit or two in the partition table], making the card useless. We used to do things like that when laptops came out and we had to bring them to shows, but we had to keep source code on them "just in case". A 540MB drive became a 539MB drive with FORMAT being the program that switched toe partition table and WIPEDISK being the new name for the format program. [Not a big secret to disclose any more - those laptops had a whopping 5MB of RAM when they were fully loaded, so that tells you the odds of any but the one I kept still being in existence. Running Windows 3.1 too.])
    Golfdriver97 likes this.
    01-15-2019 12:10 PM
  1. Phone only shows charging when turned off after water damage, any chance to fix?
    Last Post: 02-15-2019, 05:02 PM
  2. 3 months of apple music if you can fix this issue
    By criticaltactics in forum Samsung Galaxy S7
    Last Post: 01-27-2019, 04:31 PM
  3. Opening to replace sim card
    Last Post: 01-15-2019, 12:43 PM
  4. How do I know if my files are on my SD card?
    Last Post: 01-14-2019, 02:24 PM
  5. Galaxy s9 try to fix my screen phone cuts on but no picture just sounds help
    Last Post: 01-13-2019, 10:43 PM
