1. DeeNewberry's Avatar
    We have been trying to understand why, on my activity, on google, shows each site/activity shows by site name, and on my husbands google activity, samsung experience home shows up where the sites/activity should be. Is a setting different in my activity, or does anyone know? Thank you.
    01-15-2019 07:25 PM
  2. B. Diddy's Avatar
    Samsung Experience Home is just the homescreen interface. Are you both using the same browser to surf the web, or is he using Samsung Internet, while you're using Chrome?
    01-15-2019 09:45 PM
  3. DeeNewberry's Avatar
    He uses both. Chrome, and Samsung. So do i, but they atill show different in activity. His always shows SEH, and nothing else. Mine shows all the sites visited. Just odd. We cant figure it out. Could it be a setting somewhere? Thank you.
    01-16-2019 08:38 PM
  4. B. Diddy's Avatar
    Not sure why that would be. Does he tap a homescreen Bookmarks widget in order to launch the browser?
    01-16-2019 08:48 PM
  5. DeeNewberry's Avatar
    Ill have to ask. Thank you.
    01-17-2019 05:18 PM
  1. Replies: 8
    Last Post: 01-28-2019, 09:54 AM
  2. Help! Samsung Gear fit2 pro sensors stopped working
    By MsBlingberry in forum Samsung Gear Fit 2 Pro
    Last Post: 01-24-2019, 07:45 AM
  3. My Samsung Galaxy S7 is plugged, in, but won't go past 1%.
    Last Post: 01-15-2019, 10:25 PM
  4. Samsung Call App not Working, Factory Reset Fix Attempted with no Results
    Last Post: 01-15-2019, 08:49 PM
  5. Replies: 0
    Last Post: 01-15-2019, 05:24 PM
