1. DerHof's Avatar
    So I want to use bluetooth in my car but mainly for playing my music... even text notifications or phone call notifications. What I don't want to do EVER is actually TALK to someone on bluetooth. It simply sounds horrible on any device.
    So if I'm on a phone call and I start my car how do I prevent the call from being pulled over to bluetooth... or if I'm driving and I make a call the same...
    I know I can press the bluetooth icon on the screen to shut it off afterwards but I don't want it to go to bluetooth at all for a phone call.
    01-16-2019 03:29 PM
  2. hallux's Avatar
    01-16-2019 03:40 PM
  3. DerHof's Avatar
    Thanks, I was trying that but my problem was I was checking the setting while NOT connected to bluetooth.
    I had to connect to the vehicle then make the change.
    Thank you.
    01-16-2019 07:21 PM
  1. RollerCoaster Tycoon classic pulled from play store?
    Last Post: 01-17-2019, 06:04 AM
  2. from a Nokia 7 plus owner
    By Carlost88 in forum Nokia 7.1
    Last Post: 01-17-2019, 04:10 AM
  3. How do I return to gallery from viewing photo full sized?
    Last Post: 01-17-2019, 12:21 AM
  4. Why my cellphone sounds bad when connected to my car?
    Last Post: 01-16-2019, 05:15 PM
  5. Installed apps do not show on my screen
    Last Post: 01-16-2019, 03:37 PM
