1. mati111901's Avatar
    So i tried before to root installed custom recovery but forgot to download root (superSU)(I know im stupid :P)
    Installed my phone firmware to recovery cuz i had bootloop and i try Again in dev option no unlock oem (cuz i wanted to try again)Then i gave up but apps like netflix Samsung health and like that say that they dont support rooted devices any way to repair it ? Device that im using is Samsung j3 (SM-J330F)
    01-20-2019 09:43 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You would have to reflash the stock ROM. When you flashed the custom recovery, that triggered the 'root' changes that the OS looks for.
    01-20-2019 09:56 PM
  3. mati111901's Avatar
    So i downloaded rom from sammobile installed and welp still same (sammobile is not stock or i do something wrong?)
    01-21-2019 10:58 AM
  4. Golfdriver97's Avatar
    The only thing I can think of is when you started modifying the device (i.e. changing to a custom recovery), it most likely tripped the Knox counter. If those Samsung apps are reading the counter, and that counter can't be reset to the last of my knowledge, that is how they are detecting a rooted device.
    01-21-2019 04:54 PM
  1. Why when i charge my tablet the battery decreases?
    Last Post: 01-20-2019, 02:58 PM
  2. Replies: 1
    Last Post: 01-20-2019, 01:44 PM
  3. Phone does not shut down properly but blinks on and off repeatedly
    Last Post: 01-20-2019, 01:43 PM
  4. Replies: 1
    Last Post: 01-20-2019, 01:41 PM
  5. Replies: 0
    Last Post: 01-20-2019, 08:38 AM
