1. tanish5454's Avatar
    It is redgear cosmo 7.1 headset i bought otg cable to connect it to my android phone but mic is not working please help
    02-11-2019 07:54 AM
  2. SpookDroid's Avatar
    Does audio work at all? Since this is seems to be an USB headset, you might need a special app (think of drivers for a computer) for that to work with anything other than just audio. Plugged in and BT headsets are different because those are supported natively in the system, but USB ones are a different story.
    02-11-2019 12:28 PM
  1. Replies: 3
    Last Post: 02-11-2019, 01:46 PM
  2. I want to promote one of my new apps. How can I do this?
    Last Post: 02-11-2019, 12:37 PM
  3. My photos in gallery in my s9+ randomly disappeared
    Last Post: 02-11-2019, 11:38 AM
  4. My P20 Lite will not connect via USB with my Laptop
    Last Post: 02-11-2019, 06:37 AM
  5. How does the LG G7 ThinQ (G710EAW) works in Dual Sim mode?
    By Android Central Question in forum LG G7 ThinQ
    Last Post: 02-11-2019, 05:49 AM
