1. haytham-med haytham's Avatar
    Hi , after installing google news in android, i discovered i can't visit amp sites, tried chrome and firefox, also 4G and wifi, not using vpn nor ad blocker, Recieve this error https://ibb.co/H4vWVQR
    02-13-2019 05:41 AM
  2. Rukbat's Avatar
    www-pcgamer-com.cdn.ampproject.org is an improperly-formed URL. At best, it should be www.pcgamer.com/cdn.ampproject.org, but there;s no page cdn.ampproject.org at www.pcgamer.com. (www.pcgamer.com can be reached with no problem.)
    If you're manually typing that URL in, you got the wrong one. If you're copying it, or clicking a link, it's just bad. Nothing you can do about it, unless you have some other way of getting the right URL.
    02-13-2019 01:20 PM
  3. haytham-med haytham's Avatar
    Thanks for help, just found amp is blocked in my country
    02-13-2019 01:27 PM
  4. B. Diddy's Avatar
    Hmm, that's interesting. I wonder why AMP would be blocked?
    02-13-2019 07:40 PM
  1. Replies: 14
    Last Post: 10-04-2019, 05:53 AM
  2. Replies: 3
    Last Post: 02-15-2019, 02:20 PM
  3. Ghost touch during heavy load on Nougat stock ROM. What is the cause and to fix it
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 02-13-2019, 05:17 AM
  4. Why won't it come back on after it shut off on it's own?
    Last Post: 02-12-2019, 01:53 PM
  5. Load URL directly from Squeeze Ctrl App
    Last Post: 02-11-2019, 03:52 PM
