1. hrsetrdr's Avatar
    I have a Nexus 5x, and am generally happy with it. However, various settings end up getting changed accidentally, presumably by an unintended "swipe" of a [clumsy] finger.
    I like the Android platform in general, but sometimes the touch technology gets annoying, and I long for just a button or some way to put a "check" on settings changes. Some time ago I solved my "butt dial" problem by installing an app that pops up a confirmation dialogue...great solution . My wife also has a N5X, she apparently got her WIFI turned off by mistake, didn't know about it until our provider cut off our service, because she run up $300+ over the max for our data plan.
    Back to my N5X: sometimes a phone voice call just fails, one party or other can't hear, of course checked volume(OK)...??? I am aware of the BT issue with the N5X interfering with the GSM network interface, so I keep bluetooth off except when using headphones at the gym. This is a shortcoming of the phone itself,
    but I am interested in perhaps an app that prevents changing functional settings, requiring confirmation from the user.
    02-27-2019 06:38 PM
  2. Rukbat's Avatar
    Proximity Service will allow you to put the phone against anything (a pouch case, the table [face down], a belt holster [facing the holster], your pocket) and turn the screen off, so no accidental "touches". If you want to go whole hog and install Magisk root, you can install Quick Reboot Pro (it's free), and you can lock the screen with the touch of an icon. (It also saves battery, because you can quickly turn the screen off between uses.)
    02-28-2019 04:07 PM
  3. hrsetrdr's Avatar
    Thanks Rukbat, gave me some solutions to try. D/L'd Proximity Service, will see what she does.
    02-28-2019 06:37 PM
  1. S8 is showing pictures by date and I don't want them to show that way!
    Last Post: 02-28-2019, 12:33 PM
  2. Help - I need to identify this status bar icon!?!
    By fbcrft in forum Ask a Question
    Last Post: 02-27-2019, 07:03 PM
  3. continually trying to update
    Last Post: 02-27-2019, 05:47 PM
  4. Replies: 1
    Last Post: 02-27-2019, 05:02 PM
  5. Replies: 0
    Last Post: 02-27-2019, 03:29 PM
