1. Stonecold's Avatar
    How do you sync your music from iTunes to your Android device? I have an iPod touch with close to 900 songs, and couple hundreds are actually bought from iTunes...so I'm having a hard time trying to get them to play on my phone.
    Any help?
    06-17-2011 03:09 PM
  2. Bendroid55's Avatar
    Depending on how long ago you bought your songs, they will have Apple's DRM on it (I think they stopped doing that 2 years ago?). You can pay apple 10 cents a song to lift the DRM or burn the songs to a cd and import them as mp3s.
    06-17-2011 06:42 PM
  3. Dark Wizard Matoya's Avatar
    I synced all my iTunes music to the cloud with Google Music beta, but then all my iTunes songs are DRM free. If you're songs do have DRM you'll have to pay Apple to get rid of it.
    06-17-2011 07:00 PM
Tags for this Thread
