1. Gafgarion's Avatar
    I have been trying to factory reset my sons Samsung Galaxy S7 and it wont boot to restore mode even when holding the volume up, home, and power button. Im not sure how to test the volume buttons to see if they are working properly. Any advice would be appreciated.
    03-06-2019 09:11 AM
  2. SpookDroid's Avatar
    Can you boot the phone into 'normal' mode? You can test the volume buttons there. Does the Volume down + Home + Power combo work (ODIN mode)? Just in case, remember that you have to press and hold all three keys until you boot into the required mode, so try to press and hold volume up and home and while pressing then press and hold on the power button until you see the Recovery Mode.
    If not, and you CAN still access the phone, you can do the same (factory reset) directly from the phone's Settings.
    03-06-2019 09:59 AM
  1. Galaxy s9 only and 2019 Chevrolet mylink Cant answer calls
    Last Post: 03-16-2019, 10:22 AM
  2. Is it possible for my Galaxy s8 to uninstall apps by itself
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-07-2019, 10:26 AM
  3. Find update for Galaxy TAB 2 7.0 GT-P3100 to Android 5.1 (Lollipop)
    Last Post: 03-06-2019, 05:33 PM
  4. Samsung S6 Tablet. How to get permission for my mini SD Card
    Last Post: 03-06-2019, 07:27 AM
  5. why wont my hudl after factory reset only go to checking for updates
    Last Post: 03-06-2019, 06:01 AM
