1. Dathatreyareddy Ambayyolla's Avatar
    Hi
    I updated pie version in my inifinix note 5 , the notification led light not working working , I will try all types , still not working, give the Buck fixing software
    03-15-2019 12:55 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Was this an official update from Infinix, pushed over-the-air? Or did you download the update file from some website and install it manually?
    03-15-2019 09:43 PM
  3. Dathatreyareddy Ambayyolla's Avatar
    Yes it's get official, I am not download any were I get from system update
    It's showing number of times
    Then I will update date it's around 1gb
    Then after update led notification light not working
    When charging time it's working
    I will try all type of changes still same problem.
    03-15-2019 11:39 PM
  4. B. Diddy's Avatar
    It's hard to say if it might be a bug in their update. You might want to try a factory reset.
    03-15-2019 11:55 PM
  5. Dathatreyareddy Ambayyolla's Avatar
    Hi bro
    factory reset also down but not working
    Where is the problem
    03-16-2019 11:29 AM
  6. B. Diddy's Avatar
    Sometimes, an update can become corrupt during the install. Are you able to reinstall the update? If not, then you may just have to contact Infinix support.
    03-16-2019 01:23 PM
  7. Rukbat's Avatar
    Or back up the phone and flash new firmware, then restore everything you backed up.
    03-16-2019 01:26 PM
  8. Dathatreyareddy Ambayyolla's Avatar
    There have no chance to adding separate pack
    About notification light
    03-16-2019 11:29 PM
  1. My S9 plus phone is not pairing with my JLAB bluetooth headset.
    By rpk58 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-24-2019, 11:14 AM
  2. Replies: 2
    Last Post: 03-18-2019, 02:04 PM
  3. OK Google Animation not fullscreen?
    By rolexreviews in forum Samsung Galaxy S10e
    Last Post: 03-16-2019, 03:08 PM
  4. Notifications
    By kickz8 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-15-2019, 01:38 AM
  5. Content of email not shown
    Last Post: 03-14-2019, 07:17 PM
