1. jim5137's Avatar
    I have a Moto X Pure, Android 7.0, and it is a 16Gb phone, with a 32GB card in it. Lately, getting the message telling me I don't have much memory left, and that I might want to delete apps I don't use.
    Here's a screenshot from my phone, showing what is left of internal storage, and hardly anything used on my SD card, so what am I missing here?
    https://imgur.com/a/juqPWk5
    03-24-2019 11:50 PM
  2. belodion's Avatar
    What have you been saving to SDcard storage, or at least, what did you think was being saved?
    03-25-2019 05:06 AM
  3. jim5137's Avatar
    I have no idea, to be honest. I just wanted the phone to have more storage, which it obviously does, but why am I getting a message telling me my phone is low on memory, when apps are being updated, lately?
    03-25-2019 10:59 AM
  4. B. Diddy's Avatar
    Can you clarify -- did you format the card as Internal Storage or Portable Storage? I recall reading about problems with Adoptable Storage in Moto phones, where the phone actually doesn't utilize the SD card properly.
    03-25-2019 11:21 AM
  5. jim5137's Avatar
    It was a while ago, but I'm pretty sure I formatted it as internal storage.
    03-25-2019 11:41 AM
  6. jim5137's Avatar
    Judging by this, it's being considered internal storage, correct?Moto X Pure, 7.0, low memory warning with 32GB card?? Why?-2019-03-25_100508.jpg
    03-25-2019 12:05 PM
  7. B. Diddy's Avatar
    I think you're right. In that case, it does sound like what I've read elsewhere about Moto's somewhat poor implementation of Adoptable Storage. I'm not sure how to fix that, sorry!
    03-25-2019 01:50 PM
  8. jim5137's Avatar
    No worries. Apparently, it's being used a little, as 606mb have been used by apps, but there is obviously some hiccup with it.
    03-25-2019 02:11 PM
  9. jim5137's Avatar
    Anyone else have any ideas?
    03-25-2019 09:41 PM
  10. Javier P's Avatar
    I'm not sure if the card was adopted or not. To be sure tap the SD card option in your first screenshot, take a screenshot and post it here.
    Also open any picture in your gallery app and see if you get an option to move it to the SD card.
    03-26-2019 07:53 AM
  11. Javier P's Avatar
    This is the option I meant before.
    Moto X Pure, 7.0, low memory warning with 32GB card?? Why?-img_20190326_095430.jpeg
    03-26-2019 07:55 AM
  12. jim5137's Avatar
    Here is the screenshot you asked for.
    And, there is no option to move a picture to my SD card.Moto X Pure, 7.0, low memory warning with 32GB card?? Why?-screenshot_20190326-110130.jpg
    03-26-2019 01:07 PM
  13. jim5137's Avatar
    I'm getting even lower on memory, when apps update....to the point where I almost can't update any more, but I'm not technically low on memory, just that the phone thinks I am. Anyone have any ideas on this?
    08-16-2019 01:32 PM
  14. ManiacJoe's Avatar
    It would seem that your phone maker did a bad job of implementing the adaptable storage. You might be best off reformatting the card as portable storage then manually COPYING your media files (pictures, movies, music, documents) to the SD card.
    Laura Knotek likes this.
    08-16-2019 02:16 PM
  15. Ry's Avatar
    Maybe you're not using adoptable storage.
    08-16-2019 03:32 PM
  16. B. Diddy's Avatar
    We've seen posts about this before, and it seems to be mostly a Moto issue -- people format an SD card as Internal Storage, but the phone still seems to install apps to the physical Internal Storage, then gives a low storage warning despite having plenty of room left in the SD card. I've always suspected that Lenovo just screwed up with the Adoptable Storage implementation, but I've never seen any official explanation for it.
    08-16-2019 06:49 PM
  1. Why aren't my earbud controls working
    Last Post: 03-26-2019, 10:46 AM
  2. My mobile recently not working vibreting function why?
    Last Post: 03-25-2019, 04:23 PM
  3. Ride share app crashing when in drivers mode on Note 8 with Android 9 Pie.
    Last Post: 03-24-2019, 11:42 PM
  4. Replies: 0
    Last Post: 03-24-2019, 04:06 PM
