1. Ravynmagi's Avatar
    Basically what happens is any music on the external SD card will sometimes just disappear from my music app playlists. Most of the time it happens after unmounting/remounting the external SD. So I starting shutting off the phone every time I needed to remove the card. But it's happened at least once without unmounting the card.
    I could put the music on the internal storage and not have a problem, but wanted to save that space for other things. So hoping to find a way to be able to restore the missing songs back to the playlists without having to manually remake them myself.
    06-20-2011 01:26 PM
  2. Losingit's Avatar
    Having the same issue. Did you ever find a fix for this?
    08-13-2012 09:16 AM
