I've got an Android One phone, Xiao Mi A2 with Android P. My playlists keep disappearing. I'm using JetAudio Plus. I emailed them about the issue and Jet Audio said
''JetAudio use system’s media library to show the playlist to user and this system media library is managed by system. That means if your playlist gone some reason, applications can not show that to user. In most classes, it because SD card un/re-mount events. So please check why your device un/re-mount your sdcard from time to time.''
What should I do to permanently fix this problem?
My phone does not have an SD card slot.
