1. heading4tomorrow's Avatar
    I am looking for a shortcut launcher that you can swipe from one edge or corner that gives you options to make a call, change settings, open maps, etc.. not just apps or contacts, but all available tasks. Thanks.
    05-06-2019 12:57 PM
  2. Rukbat's Avatar
    There are a few apps here that add corner swipe to any launcher.
    05-06-2019 01:09 PM
  3. heading4tomorrow's Avatar
    Thanks Rukbat, I thought maybe there is a well known one that most people use. For example Swipe Master does not have speed dial option. I'll check these one by one, thanks for replying anyway.
    05-07-2019 05:29 PM
  1. Replies: 8
    Last Post: 05-13-2019, 07:04 PM
  2. We need a Samsung Galaxy Tab S5e Forum
    By athomas917 in forum Suggestion Box
    Last Post: 05-05-2019, 05:01 PM
  3. Need to find unknown sideways heart icon
    Last Post: 05-05-2019, 12:57 PM
  4. Does using another launcher (e.g. Nova) drain more battery?
    Last Post: 05-05-2019, 04:38 AM
  5. Replies: 1
    Last Post: 05-02-2019, 10:35 PM
