1. Jaffafa's Avatar
    Hello
    I have 32gb internal storage on my Sony XA1 (Plus). At the time of purchase a salesman told me i could expand the internal 32gb to 64gb by integrating an SD card and formatting it as one. (I also know you can do this on other phones).
    However, now that i have put in my SD card in, when i go into settings and internal storage, it wont allow me to integrate the new 32gb SD card so that i could format it as internal storage and make it into one.
    Does anyone know how to do this ?
    05-07-2019 08:14 AM
  2. Mooncatt's Avatar
    It should ask you if you want to format the card as adoptable storage when you insert it, but honestly, I wouldn't bother. Adoptable storage has a number of drawbacks, including early corruption of the SD card that results in data loss. SD cards are best for stand alone files (I.e. Documents and media), not app use that has near constant writing to the card.
    belodion and ManiacJoe like this.
    05-07-2019 08:38 AM
  1. What is this line on the left of my screen?
    By larman2001 in forum Samsung Galaxy Note 8
    Last Post: 05-09-2019, 03:51 PM
  2. Red tab on screen
    By paulasims in forum Samsung Galaxy Note 9
    Last Post: 05-07-2019, 10:31 AM
  3. Sony experia 10 WiFi not working
    By Robert Mullis in forum Sony Xperia 10
    Last Post: 05-07-2019, 09:44 AM
  4. Sony experia 10 WiFi not working
    By Robert Mullis in forum Ask a Question
    Last Post: 05-07-2019, 07:42 AM
