With android 9 out my background settings colors are inverted. Ive looked all over and cannot figure out how to switch it back
Long press the home screen , choose themes and it will take you to theme store , scroll down and your default theme is all the way to left corner where the check mark is just tap it.yes, this happened when Android 9 was released, I dont know how to disable all themes and get just a blank stock image to see if it changes
Long press the home screen , choose themes and it will take you to theme store , scroll down and your default theme is all the way to left corner where the check mark is just tap it.View attachment 302972
Your welcomeOk that worked! Thanks. But how do i keep it with another theme
Your welcome
You can change ,wallpaper,icons while keeping it default otherwise you have to change to different theme if u want different theme .
No problem,, anytime!Thanks!! Now i can see what settings I click on!!
