The phone was bought yesterday and just started using it this morning so nothing has been sent to it. it 32GB Storage space so still having 30GB space but nothing is entering. Please help. I don't know what to do
Printable View
Welcome to the forums. Can you elaborate your question, please?
Welcome to Android Central! Is this some no-name phone? Those are much more likely to have software bugs or hardware defects. Are you saying the touchscreen isn't working?
Please the phone Storage memory is 32GB. i try sending applications into it but it is saying insufficient memory when nothing have been sent into it. it still has the space of 30GB memory. The product is (Generic P20 android version 6.0). Thanks
Since your phone is a "generic" phone, it's possible that it doesn't actually have 32 GB of internal storage -- it might be more like 4 GB (most of which is taken up by the OS). Or it might have defective firmware or hardware. There's no way to tell, since the phone won't have any kind of support from any reputable company. I'm afraid your phone is probably worthless, sorry!:(
thanks for your reply
