1. sig99's Avatar
    Hi, what is the default browser on Android Tablets, and how long does it store the history?
    Can it store history for 12 months?
    Thanks
    Sig
    05-22-2019 09:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which tablet? If it's Chrome, the history will remain as long as you never cleared it from any of your Chrome browsers. If you cleared your history on Chrome on your computer, for example, and if you have Chrome on your tablet set to sync to your Google account, then the browsing history on the tablet will be cleared as well.
    I'm not exactly sure how a stock browser (that doesn't sync with your Google account) behaves, though. I would guess that the entire history will remain unless you clear it manually.
    05-22-2019 10:55 AM
  1. Still hearing notification sounds on phone.
    By Lecrae116 in forum Samsung Galaxy Watch
    Last Post: 05-25-2019, 03:21 PM
  2. i cant use team viewer apps to other phone on my samsung j7 max phone
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 05-24-2019, 01:44 PM
  3. Is the app Presence pre-installed on Pixel 3?
    By soonerpa in forum Ask a Question
    Last Post: 05-22-2019, 12:04 PM
  4. Replies: 1
    Last Post: 05-22-2019, 11:01 AM
  5. i cant use team viewer apps to other phone on my samsung j7 max phone
    Last Post: 05-22-2019, 05:53 AM
