For installing, in general you need to give permission to a file browser app to "install APKs", then use the file browser to open/run/install the APK.
Depending on the version of android you A30 is running, you may need to go into the phone's security settings and allow unknown APKs to be installed.
This all assumes that you have downloaded the correct APK for the A30.
