1. CellyPhoner's Avatar
    Some how overnight on all networks I connect to, 2.4 of 5ghz I get this message and no application works.
    Ive tried network reset, changing to static, changing dns 1 to 8.8.8.8, basically all the tips I could find, it seems ti happens a lot of Samsung Androids.
    I cannot use any of my msg apps without it, I really need to fix this somehow.
    I used dnspipe which installed a local VPN, but Ive since uninstalled that.
    Please help, Im desperate.
    06-06-2019 08:26 PM
  2. mustang7757's Avatar
    Check in settings>type in search bar reset network and see if that helps
    06-06-2019 08:30 PM
  3. CellyPhoner's Avatar
    Yeah I did that, I was one minute away from total factory reset haha, BUT
    I resolved it by getting rid of private DNS, phew.
    I need a DNS app that actually works but doesnt mess up my network connection.
    mustang7757 likes this.
    06-06-2019 09:04 PM
  4. mustang7757's Avatar
    Oh wow glad you found it before a factory reset
    06-06-2019 10:07 PM
  5. CellyPhoner's Avatar
    It was a last minute thing, I just noticed it. I dont know how it got in there, but it effectively has my router thinking something it shouldnt about my device.
    06-07-2019 02:15 AM
  1. Help with unknown T letter icon
    By Paultx in forum Moto G
    Last Post: 05-07-2020, 12:53 PM
  2. How To stop Software Notification On Samsung Galaxy
    Last Post: 06-15-2019, 12:58 PM
  3. My internet access stop when i get virtualsim on notification
    Last Post: 06-06-2019, 06:37 PM
  4. i replaced the screen and frame on my lg stylo 2 and now my ringer does not work
    Last Post: 06-06-2019, 04:10 PM
