    Everything is turned on as it should be, but the icon fails to appear.
    06-18-2019 12:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Just to be sure, you're following these steps? https://support.google.com/accessibi.../7349565?hl=en
    06-18-2019 04:04 PM
  3. AnnaWl's Avatar
    I am following correct procedure to turn on Select to speak, but the icon fails to appear.
    06-19-2019 05:29 AM
  4. B. Diddy's Avatar
    Duplicate threads merged. Do you see the Select to Speak option in the Accessibility menu in the first place?
    In the title of your duplicate thread, you mentioned it's a Huawei phone -- which one? You also mentioned it's running the "latest version of Android" -- do you mean 9.0 (Pie)? Or is it the latest version for that phone? Please be more specific.
    06-20-2019 12:43 AM
  5. AnnaWl's Avatar
    Thanks for merging the threads (I had to register before being able to reply to your previous post).
    It's a Huawei P20, using Android version 9.
    Thanks.
    06-20-2019 11:29 AM
  6. B. Diddy's Avatar
    Ok, and do you actually see the option in the Accessibility Menu?
    You might not be the only one experiencing the problem: https://forum.xda-developers.com/hua...perly-t3891491
    06-20-2019 01:15 PM
  7. AnnaWl's Avatar
    Yes, the function is there and all steps work fine up to the point where the icon should appear and just doesn't. I'm wondering if it's anything to do with Google withdrawing support to Huawei as part of US sanctions against China.
    Anne
    06-21-2019 12:12 PM
  8. B. Diddy's Avatar
    I don't think it has to do with the ban, because that hasn't fully taken effect yet anyway. Does this happen in Safe Mode as well? https://www.getdroidtips.com/huawei-p20-into-safe-mode/
    06-21-2019 10:17 PM
  9. AnnaWl's Avatar
    But why would there be any interference from third party apps?
    Anne
    06-22-2019 07:21 AM
  10. B. Diddy's Avatar
    There are many ways in which a glitchy 3rd party app can interfere with the system -- I don't have the technical knowledge to give details. It's a simple enough troubleshooting step to test it in Safe Mode, so give it a try.
    06-22-2019 11:00 AM
  11. AnnaWl's Avatar
    OK, thanks, will try.
    06-23-2019 07:20 AM
  1. How to wake galaxy s7 while charging to check the time?
    By zackcary in forum Samsung Galaxy S7
    Last Post: 06-24-2019, 01:23 PM
  2. Why can't I get to my home screen...
    Last Post: 06-18-2019, 10:33 PM
  3. Is there any way to force headphone mode?
    Last Post: 06-18-2019, 05:42 PM
  4. What happened to Big Launcher?
    Last Post: 06-18-2019, 04:24 PM
  5. Replies: 0
    Last Post: 06-18-2019, 12:18 PM
