can i hide notch in samsung a70
Javier P
Ambassador
Feb 21, 2014
19,480
3
is there in setting or must app
and what full screen app mean
I'm not sure what you mean by 'full screen app'.
Most phones include some options to completely hide the notch and move the status bar icons below it. This can be found in the Developer Options. I prefer using the Nacho Notch app that doesn't move the status bar but only makes it black keeping the icons on the same place.
As Mustang said some models include more options in the stock settings, usually in the 'Display' section, see if yours is one of them.
johndoe11
