1. Yuosef Gamal's Avatar
    i want to hide front camera in my samsung a70
    06-22-2019 05:37 AM
  2. Javier P's Avatar
    Welcome to the forums. You could try an app like Nacho Notch.
    06-22-2019 05:50 AM
  3. Yuosef Gamal's Avatar
    is there in setting or must app
    and what full screen app mean
    06-22-2019 09:57 PM
  4. mustang7757's Avatar
    You can see if it's in settings>display any options to hide notch or full display?
    06-22-2019 10:48 PM
  5. Javier P's Avatar
    I'm not sure what you mean by 'full screen app'.
    Most phones include some options to completely hide the notch and move the status bar icons below it. This can be found in the Developer Options. I prefer using the Nacho Notch app that doesn't move the status bar but only makes it black keeping the icons on the same place.
    As Mustang said some models include more options in the stock settings, usually in the 'Display' section, see if yours is one of them.
    06-23-2019 02:31 AM
  1. How many times can a 3000 mAh rated power bank charge a Samsung Galaxy Note edge?
    Last Post: 06-24-2019, 01:58 AM
  2. How can I stop this google text to speech in tecno wx3
    Last Post: 06-23-2019, 10:20 PM
  3. Phone is not reacting anything sd card, usb driver, even not show in computer
    Last Post: 06-23-2019, 05:58 AM
  4. can i hide notch in samsung a70
    By Yuosef Gamal in forum Ask a Question
    Last Post: 06-22-2019, 05:50 AM
  5. How to stop full screen ads in Nokia 6.1 plus Android one phones
    Last Post: 06-22-2019, 02:52 AM
