1. AirMech74's Avatar
    Ok, so what is the answer to this, i've read that you shouldn't charge your phone overnight and i've read that it is ok....what say the people?....I've always put my phone on the charger, whether it is a plug or wireless.
    06-27-2019 03:03 PM
  2. mustang7757's Avatar
    I don't think it would hurt it , as they give safe protection for battery, but what if that fails ?I Iike to watch over these things if I could nothing guaranteed.
    06-27-2019 03:08 PM
  3. belodion's Avatar
    I personally don't because of the small electrical danger. There may be other reasons not to, but I don't get beyond the first reason so I don't consider them.
    gendo667 likes this.
    06-27-2019 03:09 PM
  4. Rukbat's Avatar
    Wireless charging pads throw off heat, which is bad for the phone. (Even if it's a charging stand, the charging receiver in the phone generates heat - same problem.
    Wired charging? No problem ... unless the charging chip in the phone goes bad and allows the battery to cook. Or a storm comes up and the power line gets a few thousand volt pulse on it, which will probably fry both the charger and the phone (and could start a fire and burn the house down around you). And if the charging chip is actually charging to just a bit more than 100%, it will shorten the battery life (which is why I charge to 95%).
    06-28-2019 03:04 PM
  5. dangerousfen's Avatar
    I've charged my phones overnight for over 20 years. Never had a problem.
    06-28-2019 07:41 PM
  6. gendo667's Avatar
    Exactly. I've ruined things on an overnight charge and I'm just not willing to risk my phone.
    mustang7757 likes this.
    06-28-2019 08:09 PM
  7. mustang7757's Avatar
    I've never ruined anything doing it but I don't do it often . I deal with circuitry everyday and nothing is fail proof . It just takes one time no matter how lucky iam so I keep a eye on that .
    06-28-2019 08:14 PM
  8. Mooncatt's Avatar
    You do stand a higher likelihood of shortening the life of the battery. Li-ion batteries like a happy medium, not high or low charges.
    https://batteryuniversity.com/index....ased_batteries
    gendo667 and tube517 like this.
    06-28-2019 08:29 PM
  9. Mike Dee's Avatar
    I charge every night.....never a problem
    06-28-2019 09:22 PM
  1. Battery life not great
    By Paul Guest1 in forum Android 10
    Last Post: 08-20-2019, 07:17 PM
  2. Factory Screen Protector - Remove or Keep?
    By DFranch in forum OnePlus 7 & OnePlus 7 Pro
    Last Post: 07-06-2019, 03:00 PM
  3. Replies: 1
    Last Post: 06-28-2019, 04:32 AM
  4. How do you stop vibration on galaxy watch
    By Android Central Question in forum Samsung Galaxy Watch
    Last Post: 06-27-2019, 01:22 PM
  5. How do you stop vibration on galaxy watch
