Question about samsung usb ports
FuTure 93
Why does every android phone I buy from Samsung eventually dies because the USB ports always go out within a few years after purchase? Is this normal? I've had two Samsung phones and it's always the USB port that goes out. This phone is 3 years old and looks brand new. The port is very loose and I've kept good care with it.
gendo667
Trusted Member
Jun 6, 2015
4,492
801
113
Welcome to the forums. I've had two Samsung devices. My S10 and I kept the S8 for two years. Never experienced any problems. Hopefully someone can shed some light on this issue for you.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,384
249
63
You say 'every', then later say 'two'; so your experience is limited to two?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,536
4,673
113
Welcome to Android Central! It may be due to your habits. How do you typically remove your cables? Do you pull them straight out, or tend to do so at an angle? When the phone is plugged in with a USB cable, is the cable typically straight, or often kinked (e.g., in a car, if it's plugged into a car charger but has to sit in an awkward position)?
