can I delete my posts?
The questions I asked
Yes, not sure how you're posting but from desktop you can just go to your post, tap the pencil and then go to delete. If you can't find it, then just use the report post option (the triangle with the exclamation mark) and under the reason, state you are the original poster and wish to have the post deleted.
Ulaburgang
