1. Ne12345's Avatar
    I was connected to a bus free wifi.
    I activate the wifi, select that one and connect to it just in a New web page appeared accepting the privacy condition.
    I was connected and navigating without problem.
    Suddenly I was no more connected.
    I check others people phones' but for them was alright.
    I tried again to accept privacy condiziona, but I was in loop, the privacy condition page was chargen after I accepted.
    I was connected but I couldn't navigate.
    Please is out there anyone that can give some help?
    Thanks
    07-20-2019 04:25 AM
  2. belodion's Avatar
    Welcome.
    WiFi dropping in buses is a common experience. Attempting to reconnect via the captive portal login then fails. Why it happens I don't know but I've always assumed that it's because the bus is moving.
    07-20-2019 05:37 AM
  3. Rukbat's Avatar
    Or because some bus companies (including metro governments) use clerks to set the buses up - so they're not set up properly.
    07-20-2019 03:30 PM
  4. Ne12345's Avatar
    Maybe I wasn't clear.
    I tried to connect again, doing the same steps:
    Activate wife, select that one of my interest, the page with privacy conditions to be accepted appeared,
    I conforme, the page was recharged and appears the same page to accept the privacy conditions (it seems I am blocked in a loop) and I couldn't go online
    I tried to turn off and on the Phone but it doesn't chance the result.
    Però next to me didn't have any problem.
    07-21-2019 03:30 AM
  5. belodion's Avatar
    ^ You were clear. That is what I understood you to mean. I've experienced it myself.
    07-21-2019 09:09 AM
  1. How can I transfer files to my Android TV
    Last Post: 07-20-2019, 04:24 PM
  2. how to disable voice mail on virgin mobile
    Last Post: 07-20-2019, 04:11 PM
  3. Why are some people not receiving my text messages?
    Last Post: 07-20-2019, 04:10 PM
  4. Why does my android phone memory give error?
    By Ne12345 in forum Samsung Galaxy S5
    Last Post: 07-20-2019, 04:01 PM
  5. How to recover files from an SD card that appears as if there isn't one?
    Last Post: 07-20-2019, 03:39 PM
